I'm about half way through the piping of my Tarm Solo 30, and have all the electrical completed. I have a few questions though.
1. Will galvanized stove pipe, to connect the boiler to the SS chimney, work as long as it is at least 24 guage?
2. With the initial fill of the boiler (no storage) is there an additive I should add to remove the O2?
3. My boiler room is in the corner of the garage with about a 45' run of pex to the air handler, which is also in the garage. I'm thinking I should add some antifreeze (glycol based is what I've been told to use), but I'm not sure how much to use (the boiler holds 41 gallons). The garage has 3 1/2" insulation on all walls and ceiling and the garage doors are also insulated.
Thanks in advance
Thanks in advance
