Hello everyone,
I posted a while ago at the figuring out stage of removing an old Napoleon NZ2000 zero clearance fireplace that was set into a brick alcove / hearth. We recently moved into this home, and discovered that unit was no longer serviceable. It has now been removed (the guy unfortunately went higher than necessary removing bricks so there's now more to repair. The chimney was lined with 8" clay rounds, many were cracked and they've already been removed. The brick chimney is in the house, not outside.
The cavity was exposed and a professional was brought in for recommendation. Here's the hole -
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301690-6597a9c25bc12fc0f55eb7621fcd026a.jpg)
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301691-0896e06d3c97bef3577c3a365807e1b8.jpg)
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301692-c10798bb7b55acd913cad2287185398f.jpg)
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301693-6d2820ba090ab96bc724e6d87d503a65.jpg)
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301694-483c3467e010658740494da38b5cf4d0.jpg)
![Install of Freestanding Stove in Brick Alcove Install of Freestanding Stove in Brick Alcove](https://www.hearth.com/talk/data/attachments/301/301695-c64e02eb54f13110adc91f77b9537079.jpg)
I was given the option of -
I can get a Drolet ht2000 with blower at a discount locally. It will fit in the space and should give me the heat output and burn times I'm looking for. The home is 2000 sqft with vaulted ceilings. I'm hoping all the masonry will act as a big heat battery. Now my plan -
More questions and pictures to come,
Rob
- another zero clearance installed (big money and requires significant labour beyond my skills)
- a mason constructed firebox in the hole then slide an insert in (about 2/3 - 3/4 the cost of the zero clearance and also requires significant labour beyond my skills)
- cosmetically pretty up the hole and slap a freestanding wood stove in that hole (I can do a lot of the labour)
- by far the cheapest both labour, install complication and materials wise.
- the area is already safe and suitable for a freestanding stove (except I need to extend the hearth forwards a few inches for adequate clearance in front of the door to combustibles) All that needs to be done is make it look good.
- I expect I'll get the most efficient use of my wood / best heat into my home.
- I don't like the idea of the wood burning appliance being buried behind masonry, if a fan fails, something needs adjustment etc I can see it and do it easily.
- Stove could easily be replaced at end of life, rather than go through all this again.
- Clean out the remains of the heat exchange ducts and fiberglass you can see at the top of the cavity.
- Install some kind of plate on the ceiling of the cavity to seal and insulate that area.
- Remove the remaining bricks on the front wall, so I'm left with just the end face of the bricks on the angled wall.
- Cut away the 4-5 bricks standing proud on the floor where the front wall used to be.
- Level the entire floor and install a single piece 1" thick slate from an old pool table (already in hand).
- Cut away the protruding concrete blocks on the right section of the back wall (mason consulted and said this would not impact the structure of the chimney) to create a flush surface and also install a matching piece of slate against the entire back wall.
- For the inner side walls, I haven't yet decided whether to go with two more pieces of slate, or to run a bricks up those wall. If brick, I'll give self install a shot, but may bring in the mason to do those inside walls if I find it beyond my ability.
- Have a pro install a stainless chimney liner and hook up the stove.
- My goal here is a a strong heater that will keep the house toasty when it's too cold for the heat pump, which is about 3 to 4 months of the year.
- Will the one piece slate be more susceptible to cracking? Should I cut it up into two or four tiles?
- To create a flat surface to install the slate on, I was planning on a layer of self leveling product, pros or cons or recommendations?
- Should I lay the floor slate dry on that level surface or use a mortar?
- What is the best adhesive to attach the slate to the back wall?
- Can anyone point me to a good write up on insulating/sealing the top of the alcove?
- The stove tech is advising that insulating my chimney liner is a wasted expense. From my reading here the consensus is the opposite. Thoughts? Canada, lowest temps -25C.
- Is the outside air intake worth keeping? Can I even hook it up to the HT2000?
Rob
