I am finally finished with my install and I would like to add whatever I can to this great resources knowledge base.A quick summary of my setup.
Stove is nc30
Unfinished walkout basement install
About 5 ft. Of double wall stove pipe
Thru the wall and up 24 ft. Of class a
Supervent.
Home is drafty chalet style hunting camp
With huge windows and existing propane furnace.
About 2200 sq ft. Including basement
I've been up and running about a month now. My first half chord of wood was 12 to 15 on the mm. I had no problems getting fire started and man it burnt well. Almost too well. 600 for stove top temp was easy, I had a couple soar up around 750.
My next batch of wood was 16 to 19% and wasn' quite as predictable. One attempt at an overnighter left me with blackened glass in the morning.I think I either turned it down too soon or I closed my air too much.
It burned pretty well for another week and then a couple things changed on the same day....a low pressure event moved in, and I fixed some basement leaks with a can of Great Stuff.That day the draft started seeming week and it started to smell a bit In the house.
I rationalized it as the changing weather, and I also started cracking basement windows but each day it seemed to be worse with the smell. Then it started to smoke from my stove pipe seams when I reloaded.
Then that same night, after 2 and a half weeks of operation my co2 alarms went off at 3am ....I shut her down and started reading everything I could, all signs pointed to a blockage,including the threads on this site, yet I thought that was impossible so soon.
For me, the bottom line was this, I thought I was being clever by putting my own screen in my supervent chimney cap. I didn't want any critters coming into my chimney.....especially rodents,....I don' like rodents. I made my screen from half inch hardware cloth, (similar to chicken wire) .
I finally went up and checked my cap and was blown away by what I found, 1 side of my screen was 100% closed, the other side was about 75% closed.(kind of like my heart after my last heart attack..lolo) In 2 and a half weeks these half inch holes were completely sealed...unbelievable,
I am thankful that I had all of the threads about poor draft on this site, to finally make me go up and check. And this all happened with pretty good wood. I think my biggest problem was operator error, specifically, turning down the air too much and too soon.
I wonder if those burners with cold outdoor chimneys should even close their primary air all the way, seems like the top around the cap gets cold when you get down to Coaling stage.
I want to emphasize the importance of co detectors, they very well may have saved our lives. Please be careful if you have pest screens or spark arrestor in your cap.
And by all means, listen to those with experience on this site.operating these stoves is a gradual learning process and reading will only take you so far since each stove and situation is as varied as human fingerprints.
There is a few things I would like to emphasize for you newbies.
1: don't use cap screens unless you have to.
2: USE CO DETECTORS!!
3.use a moisture meter so that you KNOW....not think.....that your wood is acceptable.
4: practice your all nighters in the daytime when you can monitor it.
5: make sure you have safe and easy access to your chimney and cap...you won' check it enough if it is scary for you to get up that high. ( I myself must get a taller ladder).
Thank you all for your time, and to end on a high note I must say that I really love this stove, it is an impressive heat maker but you must learn how to use it. I hope my photos w.
![Install complete and chimney cap caution Install complete and chimney cap caution](https://www.hearth.com/talk/data/attachments/216/216356-2d70310edd0260038900f3b9bfb94461.jpg)
Stove is nc30
Supervent.
![Install complete and chimney cap caution Install complete and chimney cap caution](https://www.hearth.com/talk/data/attachments/216/216336-605a1c0588531bcdf99acff266728d0c.jpg)
![Install complete and chimney cap caution Install complete and chimney cap caution](https://www.hearth.com/talk/data/attachments/216/216338-bd4d772d316a1c3bd6d2083a6ea51e3c.jpg)
![Install complete and chimney cap caution Install complete and chimney cap caution](https://www.hearth.com/talk/data/attachments/216/216345-3e5c4a550380f303d810a027a7741865.jpg)
