The guy at HD knows a little about wire, nothing about stoves. A few on here have ran their stoves without the surround panels on and said the jacket on the stove was just warm, not hot. I think all modern inserts have a convection jacket all the way around the firebox. It’s a lot different than old inefficient stoves.I'm at this right now went to Home depot the p.o 'ed electrician there thought it would melt the wires. But this is what a lot of poeple do.
What is the insulation rating on the wire? Hopefully Lopi is using THHN wire. There is a 30ºC difference between TW and THHN.Travis Industries offers an inside wiring kit. It’s just armored cable. We end up using it on most flush inserts, Lopi or not.. I would remove the existing cord from your insert and run the armor flex all the way into the unit, assuming it’s a flush insert. Eliminate the junction completely if possible.
Not sure. I do know the inserts don’t even get hot enough to discolor the stickers on the jacket. We will often wrap the armor flex in ceramic wool liner insulation as a precaution. Not always though. I’ve never heard of any issues from an inside wiring either.What is the insulation rating on the wire? Hopefully Lopi is using THHN wire. There is a 30ºC difference between TW and THHN.
Often times we run it into the basement and simply plug it into an outlet. Otherwise, finding the breaker is necessary. Same thing is necessary on a Fireplace, so it’s not uncommon.My main concern is that there is not an obvious method of disconnecting (or turning off the circuit) in the room without pulling the insert. This could be a hazard with motor servicing and blower cleaning. Yes I know one can hunt down the fuse/breaker in the unlabeled panel in the basement, but a lot of people are too lazy or unprepared to do this.
Well, we are there to install an insert, not rewire their house lol.I think code requires a disconnect or switch in the room. @fbelec can verify.
