hello, me again. still working on updating my old fireplace. me and the wife have it narrowed down to 3 options (in various flavours). looking to see if anyone has first hand experience with any of these units
particulars
-large open mid 50's fairly drafty house with old windows in saskatchewan canada so im going to need the heat
current open masonry fireplace is 48wx29hx24d so fit can fit no problem (would go bigger if anyone knows of one)
-wife wants the insert to be flush and modern looking
-not going to be burning garbage but most likely a heinz 57 mix of wood
-want largest firebox and log length. epa firebox capacity ambiance/supreme 2.98 cu/ft regency 2.92 cu ft lopi/fpx 2.8 cu/ft
-price of the unit isnt a problem, rather buy the right one once than pay to install something twice
-unit will not be primary heat but try to keep my furnace off ad much as possible
-i like the burn time and effeciency CATs offer but also worry about maintenance vs secondary air
any help is appreciated
thank you for looking!
1. lopi/fpx Large Flush Wood Rectangular NexGen-Hybrid
2. Regency alterra pro i3000
particulars
- Emissions: 0.8 Grams Per Hour
- Heating Capacity:* 1,500 to 2,500 Square Feet
- Cord Wood BTU Range: 18,000 – 67,000
- Crib Wood BTU Range: 11,162 – 39,875
- Maximum Burn Time: Up to 15 Hours
- Efficiency:** 77.8% HHV
- Glass Viewing Area: 24-1/2” W x 13” H (307 Sq. In. Arch, 319 Sq. In. Rect.)
- Firebox Size: 2.7 Cubic Feet
- Maximum Log Size: 24 Inches
- Weight: 530 Pounds
- Construction: 3/16” to 1/2” Steel Plate
- Bypass Damper: Yes
- Maximum BTUs/hrinfo 85,000
- Higher Heating Value Efficiency (HHV)info 78%
- Lower Heating Value Efficiency (LHV)info 84%
- General Specifications
- Product Size Large
- Log Size 20"
- Burn Time 20 hrs.
- Firebox Capacity 3.0 cu. ft.
- Emissions (gms/hr) 0.95
- View Area 300 sq. in.
- Room Size Large
- Vent Type Stainless Flex Liner
- Vent Size (Air Intake) N/A
- Vent Size (Exhaust) 6"
- Power Cordwood 90,000 BTU
- EPA 49,358 BTU
- Burn Time Up to 12 hours
- Efficiencies G/HR 1.59 g/hr
- Optimal % 75%
- HHV 66.07%
- Dimensions Overall
- 33 3⁄4" W (Front), 22" W (Back) x 19" D x 23 3⁄4" H
- Min. Fireplace Opening
- 34" W (Front), 22" W (Back) x 19" D x 23 3⁄4" H
- Surround
- 37" W x 2" D x 25 5⁄8" H
- Glass
- 22 7⁄8" W x 15 3⁄8" H (352 sq. in.)
- Max. Log Length
- 22" Logs
- Firebox
- Cu. Ft / Log Length
- 3.2 Cu. Ft. / 22" Logs
- Soapstone Lining
- Int. Dimensions
- 22 1⁄2" W (Front), 15 7⁄8" W (Back) x 14 3⁄4" D x 17 1⁄2" H (Front), 16 1⁄4" H (Back)
- Blower110 CFM
