I have an open fireplace I'd like to convert to a high-efficiency insert. I have had a couple of chimney companies come out to look at it. Both recommended MF Fire Nova 2, and one gave Regency ci2700 as an option. The Blaze King Sirocco 25 also looks good and there is a local dealer, but I'm wondering what the pros and cons of Blaze King (which seems to be highly regarded and promoted by BK dealer(s) on this forum) compared to the other options. I wasn't impressed with the Nova 2 features or reviews.
Another question: I understand that 16" is the minimum hearth depth in front of a fireplace (confirmed with my state's residential code, which says 16" for fireplaces with <6' square foot opening). I have 18" of tile between the existing fireplace and the wood floor. The ci2700 and the Blaze King both protrude from the wall quite a bit. For example, the Sirocco 25 extends 2.7" from the back of surround to the firebox opening, and their brochure states, "If unit is installed on a hearth flush with a combustible surface, then R1.1 protection is required 19” in front of the door opening and 8” on the unit sides." I'm guessing BK says 19" because 16+2.7 is about 19.
So I would have 15.3" of clearance between the firebox opening and the wood floor. Are these inserts going to pose a problem? Do inspectors check this?
Modern inserts seem vastly safer and I'd hate to have to redo the hearth, which would add more money to this already very expensive project.
