I finally installed a key damper on my Lopi Freedom, I think it will be the only way to get good control of the fire and a long burn time without smoldering the fire. I installed it through the appliance adapter and the heavy wall liner. I blocked off the hole in the center of the damper for more reduction, flue is 29'. Here is a few pic I still have to put the trim piece now I need a cold night or two to test it.
![Insert Key damper install Insert Key damper install](https://www.hearth.com/talk/data/attachments/275/275750-f18ffdce237a53db936b72a8052f58b9.jpg)
![Insert Key damper install Insert Key damper install](https://www.hearth.com/talk/data/attachments/275/275751-a6ff8bfc1bf299a08ac01d39b28e1173.jpg)
![Insert Key damper install Insert Key damper install](https://www.hearth.com/talk/data/attachments/275/275752-844363a7b80ef9545b66be9a7b88baab.jpg)
![Insert Key damper install Insert Key damper install](https://www.hearth.com/talk/data/attachments/275/275753-5614820c720cb6752b98dad50f7880ef.jpg)
![Insert Key damper install Insert Key damper install](https://www.hearth.com/talk/data/attachments/275/275754-07e965cfb65142c0d240c4e0a8e1df5a.jpg)
