I have a splilt level ranch house. What this means is that off to one end the bedrooms are down about 3 steps from the main level and have a crawl space underneath. The same is repeated on the other end of the house which leads to the garage and down to the basement. The garge end does not have a crawl space, just a slab.
My fireplace is right in the center of the house and the chimney goes down to the basement level where there is another fireplace. The upstairs area is roughly 2400 sq ft with an open floor plan, except down the hall to the bedrooms. The basement is also open and only split down the middle to a finished and unfinished side (about 600 sq ft total).
The question I keep pondering is to put the insert upstairs or downstairs. If upstairs it is in the room we watch TV in and I don't want it to be incredibly hot when I plan on putting in a PE Summit or Lopi Freedom as a main source of heat for the house. If it goes downstairs will the heat rise and heat the main upstairs easily and keep it about 65 deg. or so? I worry then that the bedrooms that are over the crawl space would stay cold even though the crawl space has a decent opening to the basement area that would stay open to move heat into there.
Anyone have any experience with something like this? I want to get a big insert because my fireplace is very large and I'm trying to heat as much of the upstairs as possible.
Thanks,
Mike
Thanks,
Mike
