New to the board but I have searched and didn' find the answer I was looking for. I am going to install an insert into my masonary fireplace. My concerns are with the hearth clearances. I have attached some pics below of the fireplace. This is what I know for sure:
The fire box and 4" out on the hearth are masonary. What is under the tile from there out I am unsure and have no way that I know to tell without cutting into something. The hearth is 18" wide and flush with the hardwood floor in front of it. The stoves that I am looking at extend any where from 4-6" out onto the hearth. This leaves any where from 12-14" of non combustable material. Most of the stoves require 18". Although some of the literature is confusing as they state the hearth must be at least 18" from fire box to edge and later say that it must have 18" from insert to edge. Any how enough rambling. My question is do fiberglass hearth rugs or stove boards qualify as non-combustible material if there is hardwood floors underneath? If not what is the easiest way to extend the hearth? I was thinking that I could build a hearth extension that slid into the fire box and extended out enough to meet the requirements. This would just sit on the floor and be removeable so I wouldn't have to cut into the floor. I would make it about 2" thick so it would also raise the stove insert 2". I have the room inside the fireplace to do this as my opening is about 30" tall.
Here are the stoves I am considering so your thoughts on those would be helpful:
Osburn (I think) 1600 used built in 1990
Avalon 996 extended (not sure what the extended means) 1992 model
Timberwolf new
Pacific Energy Vista
Drolet
Timberwolf new
Drolet
