I was reading through the lopi leyden manual for the pellet stove I just installed. Does anyone know where to get this or did you make your own?
Good point. I took mine off and threw it in the garage. After winter, I remove the selkirk "nozzle" and place a pipe cap on the end so I don't need it during the summer.You should only need it in the warmer months when the unit is off. Not too many bugs around in the winter time & the heat in there won't allow them to live very long...
I also have the Lopi Leyden, I use one of these in the Spring after year end cleaning and leave it on until Fall start up. Keeps out bugs and moisture.(broken image removed)I was reading through the lopi leyden manual for the pellet stove I just installed. Does anyone know where to get this or did you make your own?
