On a very spur of the moment decision, i went out and bought a splitter from a local farm supple store down in the valley. Since there was little to no research done before hand, i had a hard time choosing between there two models. They had a 22 ton, and a 28 ton. The 22 ton was $1149 and the 28 ton was $1499. The 28 ton has a 10.5 brigs and stratton engine to drive it. If you want to check out the specs here is a link . I went with the 28 ton because of my altitude, every time i have bought what i thought i needed i usually need one step bigger. This proved to be the case with this piece of equipment. So far, it has handled every thing i have thrown at it, the return rate is fast, the ergonomics seem well thought out, and there is plently of power. Today, it bogged down for the first time on a wet round that was 34+ inces in diameter and 20 inches long. There was lots of branch nodes in the round, i dont think it would have been possible to split it by hand no matter how many wedges you had. It was a job for the splitter, but it got er done.
So.. here are the good points,
Relativly affordable
lots of power
very well constructed
very ergonomic
can be used in horizontal and verticle orentation
bad points
Engine is a pain in the arse to start. takes 6-10 pulls.
Gas tank is a little small, it will run 1.5-2 hrs worth of splitting
A bit noiser then the honda engine option would have been, but not bad, no earplugs needed or anything
Here are the specs for this model.
Here is the manual
Model I Beam Cyl return rate
LS401213 28 tons 6-1/2" x 8" 4-1/2" x 24" Auto-return 2-stage 16 gpm 12 sec Briggs & Stratton10.5 H.P.I/C 655
lots of power
very ergonomic
bad points
Here is the manual
