My friend is looking towards an indoor gasifier to heat approximately 4,000 sqft. The home has 2 "linked" basements and 2 separate living quarters. Both areas currently use 1 oil boiler for baseboard heat. He is thinking of adding a indoor wood gasifier in the basement w/o the oil boiler and utilizing a flat plate heat exchanger to circulate through the oil boiler.( Much like you would when setting up an outdoor wood boiler)
He will not be able to add a storage unit, but is also planning on adding radiant heat to the first floors. Any advice or recommendations? Thank you in advance!
