Indoor Wood Gasification Boiler in MA
kcbenson
42
Great Barrington MA
I'm shopping for an indoor wood boiler to add on to my heating system. Two weeks ago I knew almost nothing about wood boilers. I heated my last house for 10 years with wood (Tulikivi soapstone freestanding fireplace). My new (30-year-old) house has a brand new 134,000 BTU Buderus oil-fired boiler with a 50-gallon indirect water heater. The boiler is oversized, probably only needs to be 80,000 BTUs. House is about 1500 sq ft, but we will be adding on, heating parts of the basement, etc. A wood stove would be simpler, but there's not really a good space upstairs, and the heat system is just perfect for a wood boiler (or a solar hot water system).
Massachusetts requires ASME stamp on boilers. So far I've found only two gasification boilers that have ASME (Wood Gun and Econoburn). I'm also looking at a Tarm Solo Innova 30 with storage, but that (and other European boilers like EKO) would require an open expansion system, what sounds to me basically like a "boil-over" open tank with a drain. It's not clear yet that the open expansion system would pass muster with the local building inspector. As well, I think I would prefer to keep costs down and start without heat storage, maybe add heat storage after a winter or two of oil savings.
Anyone have any advice about which boiler to choose? Or if I should be considering anything other than Wood Gun, Econoburn, or Tarm? I'm kind of out of my league with this, so please go easy on me.
Thanks
Ken Benson
Open expansion done properly is definitely a valid installation option, and should satisfy the code officials in MA. ( last I knew anyways) If nothing else, including open expansion as an option for installation dramatically increases the number of product lines on the market that you can choose from regarding the boiler itself.
Installing a gasser now, and storage later, is a great way to spread the investment of your system out over several years. If you do this, you may be purchasing a forced draft gasifier as opposed to a draft induction style. (pusher fans as opposed to puller fans), as most of the draft induction units require thermal storage right out of the gate.
I am a big fan of draft induction, if for no other reason than they help keep the smoke and ash out of the house and in the boiler where it belongs. With some of the forced draft gasifier models on the market (not all), folks end up putting draft inducers on the stack just for reloading purposes.
Good luck with your search...
cheers
My email is kbenson at pegtype dot com. I guess I don't know how to put my email into my profile (beyond the one that I had to put into the profile in order to register).
Ken Benson
