New member here. People from GarageJournal recommended this forum as a wealth of knowledge on heating with boilers. They were right! I've done a bit of searching and have already found a lot of good opinions and recommendations. Here is a topic that I haven't successfully found: using an indoor (high efficiency) wood boiler, outside (in an insulated shed).
I started searching for a new outdoor wood boiler, after 10 years of faithful service, my current Johnson OWB ended with a water jacket leak. The initial cost back then was around $6200 for furnace and installation.
Now, we are looking at prices somewhere between $5-$8k just for a new OWB (Outdoor Wood Boiler).
Assuming the new furnace lasts as long as the old one, you can assume $600-$800/yr for the privilege to burn wood outside.
Today, I had the crazy idea of placing an indoor wood boiler, outside. I plan to build an insulated shed around it, piping into the existing pipes. I know I would have to add additional controls, but I can get those pretty cheap. I would also make an outdoor air intake for the shed. I would look for an indoor model that is insulated, with a capacity matching our existing boiler of 150,000 btu/hr.
My thoughts
Pros:
-Less annual cost assuming indoor boiler last longer, due to firebrick design.
-Possibly more efficient, leading to less wood consumption.
Cons:
-PITA to load wood. Now you would have to go through two doors to fire up.
-Shorter wood pieces
-Broken fire brick.
Please share your comments, ideas and concerns. I can't be the first to think of this!
Thanks in advance.
Ewang
My thoughts
Pros:
Cons:
-Broken fire brick.
Thanks in advance.
Ewang
