MountainStoveGuy said:
almost any ignitor that fails that often its due to excessive cycling of the unit. If the stove is always ran in thermostat mode with the wrong range it will start and stop to often and burn out ignitors. This is true for harman, quad, enviro or any other pellet stove that runs on a true thermostat mode. If the unit can be set up to cycle less, the ignitors will last allot longer. On a harman, the way to do this is to run it on the low range of the thermo setting. IF that still cycles the stove to much you might have bought to much stove in the first place. The other option is to run it on the manual mode.
I dont have a problem with excessive cycling, except perhaps in the Fall and Spring where temps fluctuate more often but it still should not lead to premature wear of the ignitor.
I cant get a full year usage of one. Theres clearly a problem somewhere and despite my efforts all the dealer has done so far is to come to my place and replace it at no charge. I am tired of it.
I want the ignitor to last more than a year. I want to be confident that I set the stove @ 70F and the stove will do its thing to keep the house @ 70 and not having me get home with a stone cold house in the middle of a windstorm in December @ night like it happened to me two years ago.
When this ignitors goes and I know it will I am going to have to be alot more persistant that something needs to be done.
