Whitfield P30 working but have an unusual issue: Stove is on a Thermostat and when it calls for heat after the initial burn the igniter does no react. When the default is cleared it works normally. This does not happen if I turn the stat down and then turn it on manually after it cools down. Things that I have changed recently were a new auger motor and a new snap switch (went from 120 to 110 degree). I have to empty the burn pot or I get way too many pellets when it defaults. I am wondering if the snap switch does not open after the initial burn. Any thoughts?
