Hi,
I have a Whitfield traditions, T300P. We recently had our annual servicing and ever since then there's been a problem. The stove will turn on, do its startup cycle, and light with no problem. Now, every time since then (3 to be exact) the stove either ran out of fuel (2x) or burned out (too lean). After each incident the stove would not start and after further investigation I found that the igniter element fuse to be burned out. The fuse is a 6A 125V fast blow. I replace the fuse, the stove starts fine, but when it ran out of fuel (yeah I know I shouldn't let that happen often) it would not restart.
The fuse either gets blown in the initial startup cycle, or when it runs out of fuel (does it try to restart?).
We didn't start using the stove until late in the season since we were waiting to get it serviced, so I don't know if something happened to it (loose wire?) then or before.
Does anyone have an idea of what may be causing this recurring problem?
A test I wish to do is replace the fuse, start it up, when burning then shut it down manually, check the fuse.
Any help would be appreciated, thanks!
-Rob
-Rob
