- Dec 30, 2013
- 273
Had a question does anyone know the ideal humidity in a home when heating with a pellet stove ?? Thanks Don
Thanks !!prob 30-50. over 50 or 60 = mold. under 30 nosebleeds LOL.
healthy humidity levels dont vary by heat source. non vented gas heat increases humidity other than that the warmer you heat cold air rh drops.
Thanks for the stupid comment .. I guess u can't fix stupid"For my birthday, I got a humidifier and a de-humidifier…I put them in a room and let them fight it out."
--Steven Wright
Thanks for the stupid reply bio burner .. Looking at your stove looks like u need a upgradeTill you get frost on the windows. Wit below zero temps that gets pretty low![]()
Steven Wright is a comedian.Thanks for the stupid comment .. I guess u can't fix stupid![]()
Actually was taken from a fixit article "What is the ideal winter indoor humidity level" Startribune 2/1/99 . There is no set level, as you can't have so much water in the home that it collects in the walls. Observing the formation of frost on windows and staying below that humidity level to keep from having other issues. Good articleThanks for the stupid reply bio burner .. Looking at your stove looks like u need a upgrade![]()
We had the same problem. I installed a whole house steam humidifier after installing a pellet stove and experiencing low humidity, creaking house and sore noses. It really bumped up my electricity bill. It was linked to my heat pump controller that adjusted the humidity level according to the outside temperature so we did not get excess humidity. I never noticed it that bad with the oil boiler.This year I installed a pellet boiler, not using the pellet stove as much and our humidity level is pretty good and have not used the humidifier at all since.I had to put in a whole home humidifier soon after installing my P68 pellet stove. It makes a big difference in comfort. And the colder it gets, the more pellets I burn and the more water I add to the humidifier. I could not burn pellets without the humidifier, now that I have experienced the cause and effect. It may sound stupid, but I can't remember being so uncomfortable when I was heating with oil hot water system prior to the pellet stove. But then again, with the P68 we are enjoying 72 to 75 degree home vs 65 to 68 degrees. The wife absolutely loves the pellet heat. As the saying goes, happy wife = happy life!
