Took apart and cleaned up the stove today and was about to sweep when I had a peek up there. I'm pretty sure something is amiss with my one year old install but want to see what you all think.
ICC Ultrablack connector. Beautiful stuff.
From stove up it goes an 18" length then joins to an adjustable length. This first join is the one in question. I can see the locking screws and pretty sure I can see the outer wall and thus a big gap in the inner pipe connection there.
It's hard to see in the photos but there seems to be a ridge an inch or so from the top of the inner wall of the lower section where the upper section should slide into to fix up the issue.
BUT, the head scratcher is that the outer wall looks to be snugged up as the screw hole would get hidden if it went down further.
UNLESS, the screw holes are not pre drilled in which case, can I can simply unscrew, tighten it up, pre-drill and screw per directions? ...
Thanks in advance for any help!
![ICC Connector experts - is something amiss with my pipe? ICC Connector experts - is something amiss with my pipe?](https://www.hearth.com/talk/data/attachments/229/229539-aecbc43dee4ee83ddfb7f5ab315b9de1.jpg)
![ICC Connector experts - is something amiss with my pipe? ICC Connector experts - is something amiss with my pipe?](https://www.hearth.com/talk/data/attachments/229/229537-68ccdf77bceb3d77971f5352ccc3c40b.jpg)
![ICC Connector experts - is something amiss with my pipe? ICC Connector experts - is something amiss with my pipe?](https://www.hearth.com/talk/data/attachments/229/229538-de728c0829e3aeea9758dc8b4a49c343.jpg)
