I think my outdoor reset unit crapped out - looking for replacement
velvetfoot
10,202
Sand Lake, NY
Not sure if this is the right forum or not - there's been discussion on this subject here in the past.
I don't think my Argo DPM-2 outdoor reset unit is working right anymore. I've checked the sensors' resistance values and they check out. There isn't much mfr. info out there on the unit. It was reasonable, seemed to work in the past, and plugged right into the Argo main controller.
The names mentioned on this forum include:
Tekmar 260
Intellicon HW+
Intellidyne
honeywell Aquatrol aq475
The heater is a Burnham V8 hot water boiler.
Would anyone have any suggestions? Maybe a heating forum?
Thanks.
VF
I just installed the intellicon HW. The guy in New York on Ebay has them for under $200.
There is another post exactly on this topic in the Green Room.
Now I'm a little handy but when it comes to electrical I shy away HOWEVER Peter S, the guy who sold it to me was very helpful. He returned calls and emails and provided the exact diagram for my Honeywell Aquastat. So much so I did it myself. There are picture of installs on this site. I hooked it up Thursday evening and it is now showing a 34.2% savings.
I know it is working as the area/room around my boiler is a lot cooler because of the lack of unnecessary burner activity... my words not the scientific explanation.
Good luck
Thanks. I'm leaning towards an outdoor reset that lowers the max temp might save more energy.
My problem is integrating domestic hot water with priority.
According to directions you can integrate domestic hot water with this. There is a separate sensor for domestic hot water.
I am an absolute amateur on this so please know that I'm just saying what is in the directions. Last week I didn't know anything about all this but a little reading and a little hands on helped me.
Good luck
That additional sensor is just for a tankless water heater which is a part of the boiler.
I have an indirect heater, which acts as it's own zone.
My existing controler, an Argo ARM-4P, has a domestic hot water priority feature in which other zones are denied heat even if the thermostats call for it, and the water circulating through the dhw tank is the maximum the boiler aquastat will allow. This priority means that the hot water will heat up faster (and it does!).
The problem is, the Tekmar 256 costs $150, but it's not exactly clear to me how priority is incorporated. The 260 model, however, incorporates dhw priority in the unit itself (along with other features).. alas it is ~$350. My price point is more in the $150 range. :)
You know more than me...no doubt.
FYI I have an Amtrol Hot water maker which I understand is like a separate zone. I didn't have to make any changes other than hooking it up. That is hooking up the Intellicon HW
Good luck
I have the same unit. It really makes a lot of hot water, and I think the priority setting helps.
This is one of those "edge case" kinds of threads, so I'm moving it to the boiler room, but leaving a link here, see if we get any additional comment - though it sounds like VF has found a solution to his original question...
Gooserider
Thanks. I'm wondering if the boiler might be "short cycling" 'cause it's really just heating the second floor. Not sure what "short" really is though. The Tekmar 256 has automatic differential that might help. It might not be as full featured as the other Tekmar units but it appears to be customizable to a good degree, has a lot of output info, and good documentation. Maybe an economizer as mentioned above would be better, but I do like the fact that this unit can be tweaked. I'll post pictures when I install it. Any operational info would be purely subjective (not that I'm not running up and down the stairs now checking stuff :) )
