I think I messed up... in the pictures below you can see a hairline crack in the foundation. Well, I bought some fast set quikrete crack sealer and put some in the crack and it ran down the crack, around the thimble. And I’m pretty sure it’s flammable if exposed to flame. What do I do now?
It is not mortar, it is some type of epoxy that hardens up when set. The bottle also says not to let it go over 140 degrees. Which I obviously didn't read until after
Do I have to chisel out the foundation wall now to get my insulated thimble back to the exterior chimney so I can have a 1” clearance?
Can I still run my 6” pipe through thimble and just put 1” chimney insulation around the 6”? It is an 8” thimble.
There is a small layer of mortar in thimble right now but will be removed obviously. Thanks
