I need HELP!!
johnnywarm
1,244
Connecticut
I bought a chimney liner kit and i think its the wrong one.It says its for oil fired alliance's.Z Flex Model "OS".
Can this be used or is there one for wood heat???
Thanks John
It does sound like you got the wrong product. It's for lower temp applications. I think the product you want is Z Flex SF (solid fuel):
Z-FLEX “OS” CHIMNEY LINER
The Z-Flex Flexible Liner is intended for use as a chimney liner in masonry
or pre-fab metal chimneys for oil burning appliances listed for use with type
L vents, gas burning appliances equipped with draft hoods or listed with type
B gas vents or listed solid fuel pellet fi red appliances whose continuous gas
temperature does not exceed 570° F.
BeGreen said:
It does sound like you got the wrong product. It is for lower temp applications:
• Z-Flex Flexible
I'm screwed.Bg what kit do i need????
I think it's the SF product. Did you already install the kit?
No on install.i need to wait till Tuesday to see if i can get one from a wood burning store.
OK, that's good news. You're not screwed and caught it in time. Good that you checked.
I did open the box and i cannot find the recite.
Does anybody know the cost of a chimney liner kit??? does it come with the flue blocking plate or will i need to make one.i'm in Connecticut.nobody here is open till Tuesday :down:
They should have a top of the flue cap, but I don't think you'll find one including a damper-seal (block-off plate).
BG do they make one when they do the install??? do you have a ball park figure on price----500 bucks????
Cost is going to depend on length of the pipe, how thick the liner material is etc. You can get one for around five hundred. The three liners I have bought online arrived in two days. They are shipped from the distributors warehouses around the country. Same thing your local dealer will do.
You can make a block off plate from an eight buck piece of sheet metal in the duct work department at Lowe's.
Thanks BB.i guess i will let you know Tuesday after 10am. i found a store in my area i think can help me.i hate waiting :grrr:
One more thing.do you just run the liner threw the block off plate or do you use two sections of liner??
One piece. All the way down.
Good thats what i thought.
Thanks again John
firebird400 said:
wait is a good thing can save your self 300.00 to 400.00 bucks and it comes in two days buy online
You betcha. The dealer is going to order it from Olympia or National Chimney Supply and get it in a couple of days also. And get a pretty penny for his light bill, water bill, rent and the phone call to the 800 number. Can't blame him. His kids gotta eat too and he has to pay the bills.
I buy all of my piping needs from my local stove shop except liners. He likes me. When I get the wrong thing I figure it is my fault and eat it instead of returning it.
I'm going to try the new dealer a couple of tonws over.if they mess it up they eat it and order again.
I'll let everyone know what they say and what i end-up doing.
I called the manufacture of the Z kit and they said i could use it if i get a Stainless cleanout T.They where very helpful and i got my answer very fast.
John
According to their website:
All Fuel Stainless Steel Kit
Part Number: 2ZFLKIT
Stainless Steel liner kit for oil, gas, pellet, and wood
. Available in 2", 3", 4", 5", 5.5", 6", 7", 8", 9", 10" diameters. Kit must be insulated for wood burning applications. larger diameters available upon request.
http://www.novaflex.com/productcart/pc/viewPrd.asp?idcategory=117&idproduct=400
Stainless Steel Chimney Liner Kits For Oil,Gas & Pellet Stoves
Part Number: 2OILKTX
Available In 3", 4", 5", 5.5", 6", 7", 8", 9", 10" Larger sizes available upon request. Alloy 316 Titanium. Patented airtight triple lock construction is tested and listed by UL
http://www.novaflex.com/productcart/pc/viewPrd.asp?idcategory=38&idproduct=399
Make sure you use the right one & there is no miss communication.Can get confusing as I am sure each dealer assigns their own part # to the same product.
Thanks Hogwildz its the wrong kit.my part # is 20Ilkitxo625
Just return the pipe for exchange or credit. If retail, just go to the guy that sold it to you for an exchange. Reseal the boxes first.
I'll try.this sucks.
John
It looks like i need a Insulating kit and a T with clean out.Does this sound correct???????The insulation kit is 285 and the T is 78 i think.
Thanks a bunch everybody your all # 1 in my book.
john
Hogwildz
If i insulate with the silver backed insulation and sock will this do??? i did also order a tee too. its coming from chimney liner depot.
John
