Hi Gang,
Here is my issue. When my stove is running, I get real nice flame going and then the feeder drops in pellets that knock the flame down quite a bit. The flame builds back up nicely and then the same thing happens. I feel like it would be more efficient if I could slow the feed rate down. Not sure how to do that.
I have a St. Croix that is an older Prescott model. The back plate says EX on it, but the EX is scratched into the plate. It is not stamped in.
The online manual shows a different control panel than what I have on my stove. (It is the manual for their newest stove.) I contacted St. Croix and they emailed me a manual for a stove that seems to be much older than mine. I guess I am somewhere in the middle.
Here is a picture of my control panel:
![I need help with my "feeder rate" on my St. Croix. I need help with my "feeder rate" on my St. Croix.](/talk/proxy.php?image=http%3A%2F%2Fi629.photobucket.com%2Falbums%2Fuu15%2Fdbn123bikes%2F1111_zps184988eb.jpg&hash=0375f81d35510f88ccc5fdddb684900a)
Here are the instructions on how to adjust the feeder rate from the manual that is for a newer model. This method does nothing on my stove.
To adjust the Feed-rates:
Hold the Auger Feed Button down and press the Heat Level High/Low button and this will
change the ON Time up or down .25 seconds from the factory setting. Watch the LED lights
to see the setting is on (it will flash the new setting). This new setting will stay in memory
from this point on. The LED lights indicate the level of adjustment and the factory setting is
the center LED light. This gives two .25 second adjustments up and two .25 second
adjustments down.
This is a picture of their late model control panels:
![I need help with my "feeder rate" on my St. Croix. I need help with my "feeder rate" on my St. Croix.](https://www.hearth.com/talk/data/attachments/143/143095-82659ff6a1351f10b4c1840ea361d7db.jpg)
They look pretty similar.
So my questions are:
1. Should my fire die down that much when pellets drop in?
2. How do I adjust my feed rate?
3. I am only using the "Manual" setting. (I assume I can still adjust the feed rate on the manual setting.)
Thanks for any input!
adjustments down.
