Im a new stove owner. It's not installed yet. Vermont Castings Dauntless if that matters.
I am building an expansion. I was proud of the layout and the work I've done so far until I realized I put the stove location dead smack in the center of a cathedral ceiling outside wall. And that's right, there's of course a beam straight above.
So I'm trying to figure out how I want the stove pipe to route. To get far enough from the roof ridge I figure Ill drop away and exit about 1 1/2 feet to 2 feet so I can get enough shingle under there and not get too close to the ridge vents. I'm going to use telescopic pipe for the vertical AND between the two 45 degree elbows to make the install easier.
<Here's my issue>. I searched and cannot find. Is there a rule for how close an elbow can be to the exit (chimney box in this case). Or is there a rule or standard for proper drafting for how far apart two elbows can be. For example having two elbows 6" apart might reduce draft more than having them say 29.5" apart? Or is that not a thing?
My goal will be to drop out of the ceiling box about 6" with a piece of double wall, then go to the elbow, use the adjustable piece to get around 30-33 inches in length before hitting the next elbow centered over the stove, then drop down about 80" to the stove adapter/stove.
![[Hearth.com] I need help making a darn decision. [Hearth.com] I need help making a darn decision.](https://www.hearth.com/talk/data/attachments/297/297770-964218413329ed98bee5eac07d48a636.jpg?hash=VD6KsHiTYl)
Good luck.![[Hearth.com] I need help making a darn decision. [Hearth.com] I need help making a darn decision.](https://www.hearth.com/talk/data/attachments/297/297776-b15880cc128c87a06fa1581528e395b7.jpg?hash=uMVxR9cRms)
![[Hearth.com] I need help making a darn decision. [Hearth.com] I need help making a darn decision.](https://www.hearth.com/talk/data/attachments/297/297778-303365b122c0a73c2f860409231e7db4.jpg?hash=MkKStXHGLt)
