I need help identifying my wood stove
Nospanko
1
Marlborough, CT
I bought a home that came with a wood stove insert. Does anyone have any idea what it is
  • I need help identifying my wood stove
No idea on the insert but you need to get that paper and wood away from the stove before you burn the new place down. Until you find the make and know clearances you should assume that nothing combustible should be within 3ft of the stove.
Just a guess here, but it reminds me of a Federal Airtight insert. Just a guess, mind you- maybe research that- see if it matches up.
Good luck.
I dont know what it is but i am pretty sure it is not a federal air tight. And rwhite is right there are way to many combustibles way to close. Have you have the system inspected by a pro? Does it have a liner hooked to it? There is probably a tag on the back or side that will identify it.
