Installing my tarm was the best home improvement I have done to date...It's the most nearly complete project I've accomplished anyway.
We moved into this 40 yr old 1320 sf ranch w/ hw bb heat in 1998. We installed our tarm in 2005. It's the best money we've spent. Our 2004 LP tally was 1400 gallons. :bug:
I like Saturdays...I can stay around the house and check the ol boiler any time I get the urge. So today, I rolled outta bed about 6am...check the boiler...draft fan is running, temp gauge says close to 170d, pretty complete burn overnight.
Last night, I stoked full load at 9:30pm (single digit temps outside...ideal weather for our no storage setup).
There's just a few glowing coals to get my kindling started. I load about 3/4 full, we'll be doing lots of laundry today using wood heated water. I make a mental note to check things again around noon...at Noon draft fan is off, boiler is a little above 180...no need to restoke yet.
I check it again about 1pm...burned pretty well down to coals...throw on some kindling, stoke about 1/2 full.
I check back around 5pm, just a couple of split remnants left no need for kindling. Now, since I just want to stretch things out to set up for a full stoke overnight, I only add about 1/4 load. 9 pm check boiler...draft fan is running temp is under 170...time to stoke.
For a full load, I usually put smaller diameter splits on the bottom, to make sure I get things cooking good before the first idle.
So that's it...that's a day in my life tediously tending my tarm boiler w/o heat storage. :roll:
For now, I enjoy it. The work is in the wood, the scrounging...cutting, hauling, splitting, stacking, moving, restacking, stoking, cleaning...but I enjoy that too. With 3 kids under eight we are home alot...if we do travel...I will light off our 40yr old LP boiler and turn the thermostats down.
In the last two years we have used less that 200 gallons of LP...for cooking, clothes drying and heating when we travel.
So that's my story FWIW...
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
