I like burning BIG CHUNKS of wood like this. How about you?...
53flyer
175
Eastern WA
I like using as large of pieces as possible iot get longer burns than if I cut them into 2 or 3 pieces. This piece was 9H x 15W x 24L and really filled the box up pretty well. I love wood that's 16-17" in diameter so I can split it in half for 2 separate loads. I usually put a few 2-3in diameter "twigs" under the large piece for kindling and to provide airflow. That's one of the downfalls I've seen with most inserts that take relatively small pieces in both length and diameter.
For some reason the flames didn't come through very well in the picture though (especially on the left side where it looks like wispy thin gases but was actually rolling flames). There were flames all over the wood and coming about half way down the glass. I'm not sure why they don't come through better other than possible camera limitations or operator error...
  • [Hearth.com] I like burning BIG CHUNKS of wood like this.  How about you?...
With my source of wood, the biggest piece I can fit in the box is the only hope I have for a true overnight "burn" just get a smokin hot coal bed and just jam that big ol' spit in there, then fill up the rest of the box with whatever you can.
It lasts a long time but burns cooler than multiple pieces. I also like the 8-10 in round ones, unsplit they seem to burn slower.
I do like them extra large pieces for when I go out for a long day, always enough coals to get it going again.
I can't fit big splits in my stove. I can actually get a better overnight burn if I pack my stove full of 2-3 inch spits. I can get more wood in the stove this way. If I try to use real big stuff I just cant get much wood in there.
3 words
Blaze King KIng
Blaze King King is King
kenny chaos said:
You'd love an OWB but not so efficient in good wood stove.
I'm not sure what OWB is.
stihltheone said:
3 words
Blaze King KIng
So are you saying the BK is good for loading with Big Chunks too? Do you also try to use big chunks?
Can any BK owners tell me what sort of size restrictions the door causes? How big of a round or split can you get in without too much trouble? For me the sizes are 10" rounds or 16" rounds cut in half which become two splits that are each approximately 8x16x24".
I don't have the space to let big ol' chunks like that season for 4 years, so I split my stuff 3-4 inch for faster seasoning. For overnights I just pack all the splits together like a puzzle in the stove.
Yeah I burn a few of those small splits in the 30 sometimes. :coolgrin:
As a reference, I use a full size coal shovel through the front door to clean the ashes. The useful area of the firebox of a king is 24" wide, 15 " high and 18 to 20" deep. You will get a 10" round through the door but you are probably only going to get two in the box before you will have to fill in with smaller splits.
OWB = outdoor wood boiler. These forced draft machines are huge and dirty which allows them to burn whole green rounds. Smoke dragons and wood consumers but you don't need to really process your wood so...
