How much wall clearance do I need with a wall pad mounted 1" out from the wall behind the stove? I need to stay as close to the wall as I safely can because of space issues. Thanks, crappdiddly46
Thanks! So,. if I understand, its 5" from a properly mounted pad 1" from the wall, and 12" with no pad?If the wall pad is ventilated behind it (open at the top and bottom by at least 1"), then 12" is the min. clearance for an unlisted stove.
Is it a listed stove? Does it have a ul tag on the back listing the clearances? If not it is like bg said 12" from the combustible wall if you use a ventilated shield. Look on the csia website for local installersThanks! So,. if I understand, its 5" from a properly mounted pad 1" from the wall, and 12" with no pad?
No 36" without the wall shield and 12" with the proper NFPA 211 wall shielding. This article may be helpful.Thanks! So,. if I understand, its 5" from a properly mounted pad 1" from the wall, and 12" with no pad?
