I hope it does not fall over...
Archer39
288
Pottstown PA
or i am going to have a lot of stacking to do. My 150 ft. stack has an area that is leaning pretty bad. Anyone have any suggestion to keep it upright for the summer? i have since pounded the wood back with the sledge hammer and it does not look that scary but i really don't want it to fall!
Next winter i will be adding some structure in between to add stability and also so if a section decides to fall it does not take out the entire thing. Its amazing how much it shifts and shrinks while it drys. Most of the stack has lost 6" of height in about 7 months.
[Hearth.com] I hope it does not fall over...
There are times when I go down the wood pile with a split and hammer on the individual pieces to straighten things out. I do it especially on the ends, beat stuff back in where it belongs. It is amazing how much the stuff moves while it dries out. I think you're stack looks like it'll survive without falling over.
Use a longer handled splitting axe to hold it up. Kinda like what you did on the far end of the pile.
Matt
If there are ever kids near that pile, I'd pull it over and restack.
Archer what type of wood is that?
zap
Agreed. My stacks never become more stable after they start to lean. Sometimes you can save it by knocking it back like you did. Or even put another row in front of it to keep it up. I've also driven in T posts in front of a stack which help a little bit.
Matt
Well, I stack on pallets also (40x48 in size). I stack waith 2 'down' and 1 'up' on either end that way my 'runs' are roughly 8' long & very stable. If I want a longer run, just add 2 more 'down' and one more 'up' - again, very sturdy (and lots of grandkids running around w/no worries). Shari
Yes, it is going to fall over. I have a lot of stacks just like that! What I do is put my back and shoulders against it and push it back into place, somewhat. I do this every time I walk past a stack that looks like it's leaning a little too much. After the first year of being stacked, it quits settling and moving so much and then I normally don't have to worry about it again.
T-posts sounds like a good idea. I've hammered back the splits & saved piles before. I've also rocked the stack back & hammered in wedge-shaped pieces near the bottom where the lean begins to level it out. I should probably just concentrate on improving my stacking ability :red: but I do pile 6-7.5' high with lots of odd-shaped pieces, sometimes in the dark, wearing one boot... ;-P
After a year or so my single row stacks start to lean. I put my shoulder or foot into them to straighten then back up.
Matt
that was just leaning against the pile. it was not there for support reasons.
zap
there is a mix of soft and hard maple, ash, black walnut, black gum, white oak and a little sassafras.
no kids around, just two dogs but they seldom lay around the wood pile.
i will have to give that a shot but i will need a step ladder the push the top of the stack. Its 5.5ft high and i am only 5'4".
Better yet...
Pull it over and make the kids restack it
