It's kind of useless. I got a Foscam IP Wireless Camera (broken link removed to http://www.foscam.com/prd_view.aspx?id=24) and it works great on my wireless network. The problem is that all I can see is a bright spot where the fire is and I can't actually see what the fire is doing at all. I was worried that this might happen so I'm not at all surprised by it. The biggest thing I wanted to be able to see is the stove pipe thermometer as my stovepipe temps tend to get a little high if I'm not right on top of the stove on start-up due to my very tall chimney and heavy draft and I can barley see the thermometer let alone the needle. The stove is in the basement so I'm using the night vision when the lights are off down there but either way, IR or no IR, I can't see the thermometer and I can't really see the fire. I'm going to try putting some tinfoil on the needle of the thermometer to see if it picks up the reflection.
I know that others have done this as well but I don't recall hearing anyone having these problems. Can anyone with a similar setup chime in and let me know how it's working for you? These camera's work great for home surveillance and security but it doesn't seem that they are a good fit for monitoring wood stoves, unless I'm doing something wrong.
