E
elkimmeg
Guest
First time I did not gain headway with my stove in my primary zone. I woke up and it was 65degrees got it to 67 and it had not moved from there since
I'm reading the thermostat located around the cornor from the wood stove to judge my downstairs zone. ITS the 45 mph wind gust raising havoc trying to bring the house up
Usually I can get it up to 71/72 and easilly 69 ,not today. I finally hooked up the burner zone valve wire. But that did not work out as planned the zone valve is gone. So I did the manual override and did circulate the zone. The real problem is this one is the primary or master zone valve. Fortunately I have 3 spear ones here so off to replace it.
Other good news the familly room Intrepid went out last night, as it will do. I should have topped off before bed time. I got up and it was 55 degrees there. IT has climbed to 66 and I feel it will make it to 70. This reduces the downstairs load and will help the stove there gain ground. Well that's the plan I hope to work out. The sun is emitting passive solar radiation. but with this wind
even that has little sffect. One can only build a home so tight and 45 mph in single digits makes it a challenge
