I am starting to get a little chilly.
wolfkiller
Burning Hunk
137
Salcha alaska
Tonight Tomorrow Mon Tue Wed 6-10 Day
Partly Cloudy Partly Cloudy Partly Cloudy Partly Cloudy Partly Cloudy Extended Forecast
High: -41°
Low: -53° High: -49°
Low: -56° High: -36°
Low: -52° High: -41°
Low: -52° High: -28°
Low: -48°
Yea these cold snaps do make you yern for summer
High: -41°
Low: -48°
What's the Blaze King up to in those Temps ?
Its appetite would be increasing considerable if it was used as an only heat source.
Mine has been certainly pigging out.
My glass is now staying clean.
I dunno how you guys do it.
I thought Wisconsin in January, and living in Vermont were cold enough for me !!
Yo North of 60,I notice your firing the Blazer King Princess.What do you think the largest Blaze King would do in your setting?Is your home well insulated or not so well insulated ?
8" walls up and down with 2' styro blue SM strapped on top with r48 attic. 12yr old house. Princess does me fine but if I had an 8' chimney the big boy would have gone in. Not for more heat but the extra extra long burn times would sure have spoiled me.
The heat output on the two stoves isnt a huge differance. Just more room for fuel on the low turn downs.
High: -41°
Low: -48°
Yup, that's a little cool, alright. We hit our lowest temp (so far) this season this morning at -27. The sun is blazing through the window looking at the frozen Bering Sea (no heat in it yet), while in my same field of view the F400 is showing a marvelous secondary burn. I've already been outside this morning to split and refill the kindling box. Boy does that go easy at this temp. Minus 27 and dead calm is a great January day for here. The dogs love going for a walk in this, and me too.
Do ya know the Carlo's in North Pole?....relatives of mine..
Is it true that spit will freeze before it hits the ground at those temps?
Matt
That BK sounds like an impressive stove!!! Stay warm (and safe)...
No, it's not true... but it will freeze very shortly after!
High: -41°
Low: -48°
That is cold brother!! Around here it doesn't get much colder than -40 and very little of that. Some people talk about such temps as if they are common but they aren't. Another comment I have trouble with is people that claim that "you get used to it". This is my 31st winter with an outdoor job and I haven't gotten used to the extremes yet.
High: -41°
Low: -48°
Holy cow! brrrrr
What stove/stoves are you using?
By the way I love your signature
I've seen -40 a few times and it wasn't that bad as long as the wind isn't blowing. When I lived in Duluth, MN I remember a -96 wind chill morning and that just plain hurt the exposed face!
Matt
No worrying about the spit, but if you have to pee outdoors.....be prepared!
I now am feeling blessed. My buddy just had his boiler and hot water heater go out. I spent the last 22hrs puting a new boiler in for him. He is out $3400 but is warm with showers again. He did not have a wood stove to heat his house while the heat was out. Lucky for him I own a lot of heaters. I then got home home to help my neighbor thaw out a frozen car. Ahhh life in the arctic. My blaze king is burning about 4 loads of birch a day now. My glass is clean. It still goes through the night no problem. I saw -63 today. I am using the furnace to heat 1 bedroom at night. The rest is still heated by wood.
FYI I have a Friend using the same stove as me (blaze king, king model) with a 16' x 6" stack and it works just fine. His stack is straight up with no bends.
So the BK works fine with a 6" flue? I see they have 8" in their specs, so I had crossed this stove off my list since I have a 6" (x 35') liner. Do they say 6" is acceptable in the owners manual?
Yep- thats pretty 'cool'.
Lived in Fairbanks for a time, still got pictures of a few of us trying to 'barbeque' some moose steaks outside one night- at -45.
Stoves are great, but I ended up getting a really good women- still keeping me warm 29 years latter ! Much better than a stove, insulation
or two blankets. Highly Recommended.
I dont believe going with 6" is recomended in the blaze king specs. I do know it works fine at my friends house though.
My stove is meant for 6". Their inserts also. Its the princess model. 2.8cuft .
Hey there, glad to see some other Blaze King users in this forum from up north. For those in Alaska, I live out west in Bethel. I've been using this BK Princess for 1 month now and love it, I should've got one sooner. It's kind of cold right now I think -20, but last week was "colder" due to strong winds. I can really tell a difference when it's windy, need to load the stove more often and use the fans on the back. With no winds it just coasts along like normal with fewer re-loads and no need for the fans.
As long as Santa stays warm, that's all that matters - my kid wants to know if Santa's okay?
60 below is a tad cool.
(broken link removed to http://news.yahoo.com/s/ap/20090108/ap_on_re_us/alaska_extreme_cold)
Hey North of 60 as I read your post again I'm still not understanding your info such as.What do you mean by 8 inch walls up and down ? Also what is styro blue SM and 2 ft. of it strapped on top of r48.Yo break it down for me in simpler terms if you will.I'm not the sharpest tack on the wall.One other thing is you said if you had the chimney you would of gone with the Largest Blaze King not because of more heat.You shared that the heat output of both stoves isn't a huge difference.I would think the heat output would be much more with the King over the Princess since the King's cubic feet of firebox 4.27 cu.ft. is almost twice as large as the Princess' cubic feet of firebox at 2.86.Give the King a half of cubic feet more firebox and it would be twice as large as the Princess.I would think this would produce way more heat than the Princess.
