Wasn't sure if this belonged here, in the DIY, or Ashcan? Anyone have an experience with these? Do they work and are they worth it, or are they bunk? Just curious. Thanks.
GotzTheHotz said:My O2 sensors are already coding since I drilled thru the cats, they are doing their thing still, but code because the fronts and backs read the same (ie the cats aren't doing anything). For what that matters, the truck is getting better mileage since I did that months ago, and performing better (and it smells better too!). As far as I know, the truck reads the front O2 first, feeds rich and lean very quick on start up, if the post cat O2 reads the same as the pre cat O2, it codes. That's all, it does engine management from the pre cat O2 only. Someone jump in if I'm wrong please? I'm thinking now, but I don't want to get killed quite yet......
Wet1 said:Like I said, it's bunk. You'll never generate enough hydrogen efficiently to aid in any significant mileage increases. Don't you think if adding this silly little contraption under the hood would yield 30% mileage increases (or even 5% for that matter), wouldn't the auto manufactures be doing it?????????????
Telco said:Not if the auto manufacturers had a lot of money invested in the oil companies:lol: ;-)
Like I said, it’s bunk. You’ll never generate enough hydrogen efficiently to aid in any significant mileage increases. Don’t you think if adding this silly little contraption under the hood would yield 30% mileage increases (or even 5% for that matter), wouldn’t the auto manufactures be doing it?????????????
No Pook is kooP. ooPk = okPo. or kPoo = koPo. It might B Poko; Pkoo, ookP... oiNkooPk said:bunk is knub? bs =sb!
did i say that right?
