hydraulic oil cooler for splitter?
michaelthomas
286
Has anybody ever installed a hydraulic oil cooler for their splitter to keep the fluid temp down? I have a cooler on my tractor for that reason. I found this on E-bay that seems like it would be pretty easy to plumb in.
  • hydraulic oil cooler for splitter?
My oil has never gotten hot enough to worry about cooling. The large tank does a good enough job cooling the oil.
I've never noticed my splitter getting hot.
If the heat was a problem, I'm sure we would have read about it here. There is too large of a group of woodburners here to have a problem like that go unmentioned.
Matt
What is 'hot'? 125 F is perfect, quite cool, yet hot enough to drive off moisture. 140 F is fine for oil. 160 F not so good, but common in industrial settings.
Logsplitters should be very cool.
excess heat means you have as problem. Oil is going across a large pressure drop without doing work. i.e. a leak, piston seals, restricted lines, or too much time holding the lever with cylinder stalled and sending oil across the relief valve.
Add a pressure gauge out of the pump or at P inlet to the manual valve and we can help you diagnose it.
kcj
Makes sense in lots of hydraulic applications that are under constant or near-constant heavy load conditions...overkill for a logsplitter, methinks. I wouldn't bother. Rick
