I was in my attic and noticed my return air duct had a butterfly damper on it and it was sealed off with a plastic bag and duct tape. I think its a 18" return duct and the damper is 8". Kind of a backstory, I always felt my furnace pulled hard. I can't run my wood stove and furnace at the same time without sucking smoke in the house. Whenever the furnace comes on, it slams all the doors in the house. Anyway, this damper draws air from the attic space. Imagine a 18" duct running the length of the house, with air intakes at each end, drawing air from the inside and a butterfly damper right in the middle drawing air from the attic. So I unsealed it, the butterfly's are loose and basically open all the time. Unsealing it seemed to help the pressure issue when the furnace runs but I feel like I'm getting cold attic air in when it's off. I've noticed about a 5-6 degree temperature drop in house since I took it off. Not sure what I'm trying to answer here but any suggestions would be great. I didn't get a pic of the actual damper while I was up there but I attached a pic of what it looks like.
![HVAC question HVAC question](https://www.hearth.com/talk/data/attachments/308/308580-21ff08c4f854164b7491ec43b2270188.jpg)
