SO half rant, half curious what people think here.
I have a frankenstein cabin that Im trying to figure out how to get heating/cooling in there. Right now, it has a very old trailer oil furnace that blows into two sides of a 20x30 cabin. Attached to this cabin also is another 20x30 expansion, half of which is a 'sunporch' the other half is our bedroom. This was built on telephone piers scooped out half moon with telephone poles laying down on those as support. Not joking, then oak flooring (not T/G and you can see daylight). This area is heated with ONE 8' baseboard that actually does the job rather well until the temps dip below 15 deg f or so, and there is a strong wind underneath (not insulated, I plan to address this). There is also another 10x8 expansion that is literally just built inches from the dirt that I dont have access to underneath or above. This is a bunkbed room/office. And wait, there's more, I just put on a 24x26 expansion.
The bunk area has no heat, it just gets heat from the main area naturally but it gets cold in there without a space heater.
The new expansion (24x26) has a new VC stove in there so Im not worried about that area for heat. In fact, it was only 6-8 degrees cooler than the main area at most during the winter last year because I used the absolute most insulation I could when I built this area. Im hoping the VC stove puts heat into the other areas as well.
So I'm not too concerned about heat, but where my oil heater is at , it takes up alot of real estate for an area that I would like to take over for a washer/dryer , water heater, and to the one side a mini bar. Not to mention it is very old.
I do have a small attic in the main cabin area that is 5' tall at the tallest then it goes out from there 4/12 roof pitch, I could hit the two other main areas easily from there within 10' or so.
I called 8 different hvac companies in the area over the last 5 years or so, including one that comes out and cleans / maintains my current 1970s oil furnace. Only ONE group, 5 years ago, provided me a quote for 3 mini splits (I really need four) and they wanted 18k. I really didnt like the idea of mini splits to be honest. I dont like how they look, and I dont want to heat the place other than to a bare minimum while we arent there. My neighbor has a mini split and it takes forever to heat his place. He kicks it on thursday for friday arrival and it's generally about 60 degrees at the time when he arrives, then he kicks on his stove. He loves the AC though and feels it's better for that.
I really wanted a conventional system and even considering trying to DIY it, using flexible ducts with foam insulation wrapped around them to make it easy to run duct work to the various locations. They use this stuff in office buildings ALL the time, I see it when I used to pull wires through drop ceilings etc. But no one wants to quote me for that. They all say, oh no you cant get that - you need a mini split that's pretty much your only option, ....then they never provide me a quote.
For a mini split, the main unit would sit outside the new expansion, about 3' off the ground mounted on a wall. Im not saying it would be easy, it would take two guys two days of work for sure. 3 runs would run up through the soffit of the new expansion into an area where the old/new roofs meet..sort of an attic with a sloped from / shingled from the old roof, then it would run into the old attic and would hit the OG cabin, new expansion and the bedroom. The 4th run would literally just go feet away sideways and up to hit the tiny bunk room.
I considered just getting one of those crawlspace dehumidifiers to try and keep the moisture down. That's our biggest issue during the summer. It's like a swamp there, and very uncomfortable. Indoor humidity exceeds 80% and it's causing some of my new wood work to buckle. I've had to cut expansion spaces into the smaller pieces, and the larger ones are pulling away from the wall my to my shock/surprise. Not alot but enough that a rubber mallet forces them back 1/8 an inch flush to the wall. All t/g paneling. So I have to do something about dehumidification (or start adding more expansion joints between the boards when Im putting wood up/around during the summer). It would be nice to be cool during the day/night as well, not cold but cooled off a bit. We have a window AC in the livingroom, and one of those floor model / window pipe exhausts in the bedroom. The one in the bedroom just cools things down to the point that you can sleep a bit but the humidity is still so high it feels like you are sleeping on wet sheets.
Anyway, just random ramblings about my situation. Hard for people to envision for me what I have to deal with , without extensive pictures. Just curious if anyone else has had a similar experience and what they did about it.
