Husqvarna 365 Special
mellow
Resident Stove Connoisseur
5,885
Salisbury, MD
Hey guys, I have come across a rebuilt 365 special with a 20" chain, As per the seller it has a new starter cover, ner bar cover and has been totally rebuilt from the crankshaft out, seals bearings, pistons, rings. This saw has about 25 hours since being rebuilt and runs excellent. The guy is asking $275.00 for it, from what I have read so far it seems to be a good saw, just wanted to double check before I spend that kinda cash.
  • Husqvarna 365 Special
Never run one. All I know is they are a pro quality saw not sold in U.S. anymore, but still sold in Canada. Basically a 372XP with a smaller P&C and a little lower-revving, torqueier set-up. If you cut decent sized wood it should do well for you I'd guess. Should pull a 24" B&C very well if needed.
---Edit--- I see it's the 365 not 365 Special that's still sold in Canada. Here are specs for the current 365:
Engine specification Cylinder displacement 4 cu.inch / 65.1 cm³
Power output 4.6 hp / 3.4 kW
Idling speed 2700 rpm
Maximum power speed 9000 rpm
Cylinder bore 1.89 inch / 48 mm
Cylinder stroke 1.42 inch / 36 mm
Ignition system SEM AM50
Ignition module air gap 0.01 " / 0.3 mm
Spark plug NGK BPMR7A
Electrode gap 0.02 " / 0.5 mm
Carburettor model name C3M-EL2B
Fuel tank volume 1.62 US pint / 0.77 lit
Oil tank volume 0.84 US pint / 0.4 lit
Oil pump type Adjustable flow
Oil pump capacity 4-20 ml/min
Cutting equipment Chain pitch 3/8"
Recommended bar length, min-max 15"-28" / 38-70 cm
Chain speed at max power 67.91 fts / 20.7 m/s
Emission, vibration & noise data Equivalent vibration level (ahv , eq) front / rear handle 3.6/3.5 m/s²
Sound pressure level at operators ear 102.5 dB(A)
Guaranteed sound power level, LWA 114 dB(A)
Overall dimensions Weight (excl. cutting equipment) 13 lbs / 6 kg
Maybe 365 Special has a larger P&C?
Seems like a pretty fair price......
If you don't buy it, I will ! :)
If it checks out and was rebuilt by a competent person or a dealer, it is worth $275. Very good saw.
I would do it. I paid a hair more for my Makita 6401. Get cutting!!
Mike
Well I picked the saw up yesterday and put it to work. Put it to the test on a nice size silver maple, my 42cc 18" craftsman took about 15 minutes to cut through this thing, the 365 does it in about 4 minutes! That 20" bar sliced it like hot butter.
Glad you're enjoying it....... those 2 saws are both chainsaws, but beyond that, they really have nothing in common LOL.
Congrats on the new saw! Good tools definitely make the work more fun.
I would run it til she blows ( if that ever happens) Then up grade it at that point.
mellow said:
Anyone done the muffler mod to the 365 special before? Did you see a difference in power? I was also looking at the cylinder and piston upgrade to make it a 372xp, did you do it yourself or did a shop do it for you?
shoot me a PM and I'll help walk you through a muffler mod........ definitely worth doing on this saw.
I wouldn't make it a 372 right now.
I've had a 365 Special since 2000. Only problem I've ever had is a mild acceleration problem I can't seem to get rid of even after adjusting the carb. Just tends to bog when gassing it off idle. Other than that for a 10 year old saw it runs great. If you can believe it I picked up a nice used 394XP with a 24" bar for $275 in the spring. Wanna see wood cutting, hold on! That sucker makes it look like its snowing!
