Husqvarna 365 mod question
kevinmerchant
114
Cheshire, CT
Can any 365 be "changed" to the power of the 372 or is it just the x-torq. There seems to be 3 different models, the regular 365, the special, and the x-torq.
I currently have a 029 super which I believe is 56cc. Would I notice a big enough difference to the 70cc.
While I cannot tell you if it is possible to upgrade your 365 to the power of a 372, I can tell you that you WOULD notice a difference going from 56cc to 72cc. Just by the power at the bar alone. Put a 28" bar/chain on a 56cc saw and try to run it through a big log once......it'll be draggin it's a$$. Put that same bar/chain on a 72cc saw and go through the same log. HUGE difference.
How many cc's is a 365?
I betcha its 65cc. I think he got his 5 and 6 backwards! If that's the case, he's not going to see much of a difference........
Never have really figure out the husky other than a 372,395,3120....;)
I'm newer to the Husky thing (still a Stihl guy at heart;)), but I think, as far as the 'newer' XP models are concerned, the last two digits of the model number is the CC of the saw (372XP is 72cc, 365 would be 65cc), not sure though. I'll leave that to the Husqvarna experts!
Reactions: Thistle
Yes, the 365 is 65cc. I have the 365 Special. You can put a big bore kit on it to make it a 72cc.
Reactions: ScotO
Not to mention my 24yr old 288XPW @88cc's. I've even thought about putting a 95cc big bore kit in it in a couple yrs.::-) Though with buying the parts first & paying my local trusted shop the going hourly rate to install them - I'd probably be better off just to buy another saw. Hmmmmmm....;)
Reactions: ScotO
Put her together yourself Thistle. Not a big deal @ all.
To the op, 56 to 70 cc is a whole different world. There is no replacement for displacement. A C
Reactions: Capt and ScotO
372 top end is a direct bolt on. The 365 will already be a big difference from the 029.
Reactions: ScotO
Do they make a big bore kit for the 372XP? If so, what does that bump the CC up to? Thinking about going all out on my XP this winter, but the way it's looking I'll be running the damm thing every weekend right through February! Naw, I'll use one of the Stihl 041AV Supers. They're still my favorite saw.....
I'd pass on the big bore kit also.....especially in favor a port job.
Mine has a ton of power and will pull a 32" bar. I'm going to send my 260 down to the builder this week.
Reactions: ScotO
I see Mastermind over at AS did your 372XP. Whatcha have done to it?
029 Super to ANY pro class saw is going to be a noticeable difference. Not just in power either. ;)
Woods port and a cut squish band. I highly recommend his work. Great guy to deal with as well.
yes I have been talking to him, I'm gonna have him do one of my 041AV Supers sometime this winter. I've seen some of his before and after videos, and I'm impressed.....
If it's a regular 365 or a special, then it's a 65cc saw and requires a piston and cylinder swap. If it's an x-torq, then it's a 70cc saw and requires the limiters to be removed from the transfer covers. Either way, I think it's worth the upgrade.
Here's a vid explaining the x-torq mod
Reactions: Nixon
To anyone considering buying the 365xt, do it now. Husqvarna has already raised the price $90. Existing stock will be sold at $620 msrp. All new stock is going out at $700+.
