Borrowed our local fire chief's 22 ton Husky splitter (the TSC one). Works great, but I want to be sure to return it better than I got it so I have a couple questions. I ran a few tanks of gas with seafoam in it to clean out some of the gunk...starts alot easier now.
- It needs an oil change...may have never had one...whats in there is gray and gross. What is the mfr recommended weight and quantity so I cna change it for him?
- The auto return mechanism doesn't seem to work very well. When I remove the splits and push up on the controller, its supopsed to stick in the return position till it gets the cylinder to the home position. But it keeps popping out, seems to get slightly better when its good and warmed up, but it never really works properly...does this indicate an adjustment required or a bad controller?
- There is a definite metallic vibration going on when the cylinder is either idle or moving towards a round, when it contacts the round the noice goes away...I haven't found any obvious loose bolts or broken weld seams, but I want to see about tracking down the problem.
- His 2" ball and hitch for his Explorer got swiped so he can't tow it, figured I'd buy him a new one as a thank you.
I want to take care of these minor issues for him..I'm the kind of guy that never borrows a car without filling the tank when I return it and I just want to be a good guy and take care of a couple thigns for him, even though I didn't cause these to happen...he didn't have to lend it to me, I want to do right by him. As an added bonus, taking good care of other people's equipment usually makes them want to lend it to me again when I need it.
Thanks.
Thanks.
