Husky 445 Severe Oil Leak
walhondingnashua
708
ohio
An guy gave me a 445 that he did not want to mess with so he went and bought a new saw. It runs great but leaks oil far more than any normal little oil leak I have seen in other saws. Is this common for this saw? Where should I start looking to fix the issue?
Clean it up then follow the oil.
It's probably from the oil pump or oil line,or maybe a cracked tank
Reactions: johneh
A lot of huskys have an oil tube in the bottom of the tank that dry rots and looses it's seal. Pretty easy replacement. I have done it to a few. Takes about an hour.
Well known issue on these saws. My 55cc rancher does it. Never got around to fixing it, I just try to coordinate the end of my cutting sessions with an empty oil tank. The oil stain on my garage floor shows how well my technique works.
Reactions: ozarkoak
I do the same timing with an 024 Stihl that leaks oil when it sits. Amazon keeps me supplied with clean cardboard to place underneath.
Oily cardboard is excellent fire starter
