Hello all, I need some help please. I 'tried' to adust the detent as my return was not stopping as quick as I would like. I took the cap off, removed the large bearing and found the slotted top. It was not turning at all. After applying a decent amount of force to it, I decided it wasnt worth screwing something up so I stopped. One thing I did do was I pulled up the outer sleave,, and yes to my surprise 4 little bearings popped out. Good news is I was able to find all four, whew![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
My problem now is,,, I put the spring back, then the 4 bearing, the sleave (with the 2 grooves at the bottom) then the large bearing,,,
It wont work,,,, the cylinder is all the way out,, it wont retract. What am I doing wrong please??
