Hey everybody.
I've been lurking here a while and learned lots but now I need some direct guidance.
I built my own hunting/camping trailer and just recently built a wood stove and installed it in the trailer for quiet heat while hunting moose up north.
I've done a few test burns keeping track of temperatures at critical points and I've come to the conclusion that the stove works too well. I'd like to be able to burn it less hot while maintaining safe flue temps to not build creosote. With a minimum charge of wood or even compressed logs and the air intakes closed down to minimum allowing proper flue temps, the temp inside the trailer quickly skyrockets above 40C. If I wait for the temp to drop down to comfortable levels in the trailer (several hours), there are no coals left to start the next log and I have to make a new fire.
The stove is fairly high tech for being home made, it has primary and secondary air dampers, a downdraft baffle plate and fire brick insulated firebox. The current flue diameter is 4" and the chimney is right around 6' tall. The firebox is roughly 9"W x 13"D x 10"T.
Everything works as it should and smoke never enters the trailer even with the door wide open. It reacts well to being dampened down and obviously throws insane heat. The 4" flue runs through a 6" stovepipe insulated with stone wool to protect areas where it passes through the trailer and keep flue temps high.
Now for my question, if I modify the stove and run a 3" double wall SS stove pipe through the existing 4" flue (effectively making a triple wall flue to quadruple wall insulated chimney) can I expect hotter flue temps with a cooler stove temp and increased burn time with reduced heat output?
The firebox is sized similar to a cubic mini grizzly and they use a 3" flue system. I would simply do my own tests but the 3" flue is going to cost around $200 CDN and I would like to be reasonably sure this is going to work before ordering.
I will post some pics so you can get an idea of what I'm talking about.
![Hunting Trailer Mini Stove Hunting Trailer Mini Stove](https://www.hearth.com/talk/data/attachments/258/258006-3e912352b7d83efaa501e791241b3c40.jpg)
![Hunting Trailer Mini Stove Hunting Trailer Mini Stove](https://www.hearth.com/talk/data/attachments/258/258007-2ebd8ed412023bac41bd34df1f04624c.jpg)
![Hunting Trailer Mini Stove Hunting Trailer Mini Stove](https://www.hearth.com/talk/data/attachments/258/258008-0adfe5933763b54b6f7dd41a4d107227.jpg)
