lordgrinz said:I am assuming less than 20% humidity might be an issue?
poconoman said:lordgrinz said:I am assuming less than 20% humidity might be an issue?
Is the XXV have a hot so you can place a cast iron kettle? The PC45 gives off radiant heat and the top is HOT.
Craig Miller said:poconoman said:lordgrinz said:I am assuming less than 20% humidity might be an issue?
Does it have to be cast iron or will any tea kettle work?
Craig Miller said:Thanks. I just installed a Whitfield that has trivet on top. I'm going to see if it will work with an antique kettle my grandmother gave me (still in good condition).
