Hello
On the HR West point when I first fired it up, I noticed the fire pulling toward the Top Feed drop chute. I believe it may have been after the convection blower started. Thanks Smokey for alerting me to this!
The back of the fire box around the drop chute is a double wall. However it is NOT very well sealed. So on the inside of the stove where the drop chute goes thru the 1st layer of the double wall there is quite a gap all the way around the drop chute!
Now the room blower is 140 CFM so when kicking it up, It may be pulling some air out of the burn box. I do not see any smoke. The inner fire box wall near to the flame is tight around the opening of the drop chute.
First, I cleaned the edge with a rag and some fantastic.
Then I got a small piece of rope gasket and coated it with Hi Temp Clear Silicon and put it in the gap all the way around the drop chute. Then added more silicon on top.
As you can see in the before fix pic, there is a hole in the flame. Also when on the low # 1 or 2 setting the flame really pulls towards the drop chute opening.
The ash traps on the outside of the unit look fine, so I do not think they are an issue.
However if removed then adding a gasket may still help them being re-seated properly.
Then next time I fire it up, I will see how the flame reacts.
Has anyone else done this? What changes in the flame did it make?
