This is a safety feature to prevent burn back up the auger tube and into the hopper. Personal I would not change the default settings that said it is your stove your house. The C codes C19 and C20 can shut off this feature set either or both to 0 and it will not bump any pellets on shutdown. If you just adjust C20 you can shorten the time pellets are pushed into the burn pot on shut down thus you will have less pellets in the burn pot. C19 controls the rate lbs per hour adjust lower less pellets, again setting either at 0 will stop the bumping at shutdown. If you want less pellets at start up you could adjust C15 this adjust the time pellets are pushed into burn pot at start up, less time less pellets. Your default rates might be different then those stated. Again burn back into the hopper is a real thing so make any adjustments at your own risk.
To adjust the operation constants "C Codes" , press the hold the MODE and AUGER DELAY buttons simultaneously
for 3 seconds. The display will show “C-1”. Use the HEAT RANGE UP or HEAT RANGE DOWN buttons to
change the constant number (see the list of vales below). When the desired constant is displayed, press
the ON button to toggle between viewing and editing the value. While editing a parameter, use the AUX
again to return to the constant number list. Press the OFF button to exit the operational constants
mode.
C15- Auger load time (0-30) – This variable is used to control the length of time that the fuel is
augured into the burn pot during startup. The default is 6 minutes.
C19- Bump rate in pounds per hour (0-0.5) – The bump rate defines the rate of fuel to be
delivered when the unit is over temperature or in shutdown to prevent burn back
C20- Purge time (0-120) – The purge time defines how many seconds to run the auger to purge
it on power down or shutdown as the stove moves from a warm state to a cool state. It is
intended to push and partially heated pellets still in the auger tube out. By default, the auger
will run for 30 seconds, but can be set between 0 and 120.
Hello and thx agian for this awesome answer...it worked like a charm and due to my theory adn stove design, back burn was not possible.
Saved me a hack of tinkering...thx again...
When you now also know how to deactivate the lid switch...i mean without tinkering on the hardware?!?!
I have collected so far this info...maybe you know any more of the missing ones...
THX
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
C- 1 - Reset to defaults (hold Mode and Auger Delay buttons for 3 seconds to
reset all to defaults)
C- 2 - Fuel Lbs Per Hour HR 1 (0-5.0) - This is the fuel rate in pounds per hour
for a heat range setting of 1. The default is 1.75lbs.
C- 3 - Fuel Lbs Per Hour HR 9 (0-5.0) - This is the fuel rate in pounds per hour
for a heat range setting of 5. The default is 4.5lbs. The fuel rates used between
settings 1 and 5 are linearly interpolated between these two settings.
C- 4 - Draft Fan Level HR 1 (0-500) - This is the Draft fan output level for a draft
fan setting of 1. The default is 100/500.
C- 5 - Draft Fan Level HR 9 (0-500) - This is the Draft fan output level for a draft
fan setting of 9. The default is 300/500. See next parameter for disbursement.
C6 Auger on =0 Auger off =1
C7 Temp Ramp up time? Default =120sec
C8 Start up time out Default = 30mins
C9 Over temp Shut down Default = 445*
C10 Over temp cut back Default = 430*
C11?
C12 Room fan start up temp Default= 110*
C13?
C14?
C16?
C17 Calculate ambiant air temp default = 0 (will expand later)
C18 Room Fan Full on Default 0 (normal operation) 1= full on
C21?
