I couldn't find a topic that covered this everyday problem. Several threads involve it but I was wanting to see a more comprehensive source for info, a "Thermocouples for Dummies"
I have a type K I'm working with and it plugs into a printed control board. I'm not familiar w/that arrangment.
I aasume it shuts down the auger when the exhaust gets to hot?
I heard I can get a millivolt tester and do some math based on a given range (on a table) and temperature and figure it out. Or use a lighter on the TC and get a test reading that should be in that range. I prefer Farenheit over Celsius whenever possible. http://www.pyromation.com/downloads/data/emfj_f.pdf
Some testers do the math. Can it be done without that tool?
I have a thread-in pop-up tester I used to use on mobile home water heaters and downflow gas furnaces. Are all Tc's the same thread size? I paid $13 for the tester 15yrs ago, I don't see it for any less than $30 now. (broken link removed)
Thanx for any experienced input
EDIT- what's the temp range on these? 32 - 1400F doesn't sound quite right. (broken link removed to http://www.omega.com/temperature/Z/pdf/z203.pdf)
EDIT- They may go from -340 to 1650F I think what I want to know is what is the range used by my stove. I was wondering what the max temp was going thru the vent.
