My pellet stove is an insert with exhaust and inlet inliners all the way up to the chimney top. we didn't use it this year. I can feel strong draft from where it is. How can I stop the draft or make it lose less heat when it is not in use?
Stuff the area where your old fireplace damper is/was with insulation and then seal it with thin piece/s of sheet metal fashioned with holes so you can run your exhaust/air inlet pipes through it. That is, you're creating a damper of sorts that seals the space and you place insulation above it. Good luck.
Yes, we sealed the gaps between the steel pipes and the chimney. I think most of the draft is from the steel pipes, exhaust pipe and air inlet pipe, which are connected with outside.
If your insert has a damper on it, close the damper that should at least greatly reduce any air flow and hence cooling of the stoves pipes.
When you have a chance please take a picture looking up at the block off job you did and post it along with a description of how the block off was done.
If you have a easy to move insert and a quick disconnect, you can also plug both of the pipes. Just be certain to leave yourself a note where you can't miss it.
As long as you have an outside air kit the stove is a closed loop. The draft is coming from the chimney, a 4-6 inch thick block off with Roxul should eliminate the draft. I would do 2 layers, a looser layer above a tightly packed around the pipes layer.
