Haha, thought the title would get you!
ONLY CONDONING THIS FOR TESTING PURPOSES, NOT ORDINARY HEATING. You paid for the ESP, so use it. ;-)
Since Harman stoves use an ESP to control everything behind the scenes, most of us now know that you can't really use the convection air to determine heat output of various pellets...UNTIL NOW.
It's simple, just set the stove to Stove Temp, turn the temp dial to 7 (Max) and the feed rate to around 1 or 1.5. Feed rate doesn't have to be exact, it just needs to be low enough to not hit the max allowed ESP temp. Now you can measure the max convection temps of different pellet brands. Only catch, you cant touch the dials or you'll never reach the same values and your evaluations will be flawed. To get around this, only use a few pounds per brand and you could test several over the course of a day.
And, if you're like me and PJPellet, you can cheat and use your Harman Diagnostic Tool to compare the ESP temps for different pellets since the tool give the exact temperature. Tool can be used to get the knob values exact as well, but I didn't want to rub it in.
Hope this helps! Have fun![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
