Hi,
I have a Vermont Casting Winterwarm large insert. I need to remove the damper assembly in order to replace it. I have all the panels removed from the top, sides, back and bottom, the two bolts, and the damper arm. The damper assembly frame moves a very little, like a 16th of an inch, in and out (front to back). There is nothing obvious that I can see/feel holding it in. Is there anything else I need to do to be able to remove this damper assembly? Any suggestions appreciated. Pictures enclosed.
Thank you,
Austin
![How to remove damper assembly from VC Winterwarm large? How to remove damper assembly from VC Winterwarm large?](https://www.hearth.com/talk/data/attachments/271/271815-5dcb4d8b102237cad5342968eda8b13c.jpg)
Thank you,
Austin
![How to remove damper assembly from VC Winterwarm large? How to remove damper assembly from VC Winterwarm large?](https://www.hearth.com/talk/data/attachments/271/271813-a8a90b0252bbefc4c739885cd780655b.jpg)
![How to remove damper assembly from VC Winterwarm large? How to remove damper assembly from VC Winterwarm large?](https://www.hearth.com/talk/data/attachments/271/271814-f2b2185adf9b963c23957f939398ae46.jpg)
