Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I need to size out the length of for a stainless steel chimney liner, so I know its going to be a 6 ". From what two points top and bottom do a take to measure out the length of the chimney?
Check your stove manual. From just above the top to just below the damper you may find a lil short.
I know PE says from chimney top to existing fireplace floor. You will lose some as it bends through the damper area. Better too long, than too short.
Most come in pre determined lengths. That will also be a factor.
